Generating Custom Output
AI Render offers a few different ways you can generate or refine an image.
Text Prompts
Creating a text prompt for generative AI tools can be tricky, especially if you want specific output. See Best Practices for Custom Prompts for some guidance on crafting prompts.
Presets – Select from Auto or one of SketchUp’s preset prompts to generate a certain look and feel. For more information on how they work, see Preset Prompts .
Add a Reference Image – This option is available only in the “No Style” Preset. Clicking this option opens your device's file browser where you can select a .jpg or .png.
Erase
Note : These optional drawing modes are only available in SketchUp for Desktop and SketchUp for iPad.
Brush Mode – With Brush mode you can choose a diameter for your virtual brush then color in the area you want to erase. Brush mode is activated by default.
Lasso Mode – Similar to SketchUp’s Select tool, you can circle the area you want to erase.
Drawing slightly outside of the area you want to modify can help improve results by giving a bit more context. Once you draw over an area, click Generate . AI Render will generate results in the Gallery. If you leave the tool and come back your selection will persist. You can clear the mask created by the Erase tool by clicking Clear and Reset .
Paint
After using Paint to generate output, AI Render will revert to the Text tool by default. You can still access the masks you generate by selecting the Paint tool again.
Sketch
You can add both a regular or negative prompt as well as adjust the diameter of the lines you draw. Clicking Generate creates output using the drawn image and your prompts. If you leave the tool and come back your selection will persist. You can clear by clicking Clear and Reset .
After using Sketch to generate output, AI Render will revert to the Text tool by default. You can still access the masks you generate by selecting the Sketch tool again.
