SketchUp Desktop 2024.0.2
SketchUp Pro 2024.0.2
24.0.594 Win 64-bit
24.0.595 Mac 64-bit
SketchUp Release Notes
Graphics
  • Fixed an issue where certain large models would not render properly when Multi-sample Anti-aliasing is set to 2x/4x on some Mac Laptops.
Live Components
  • Improved management for Live Component materials in SketchUp. When a material is changed in a Live Component, SketchUp now applies the new material to the user selected material. Only the user selected and applied material shows in the materials panel.
Extensibility
  • Fixed reported security issues in the SketchUp SDK (SketchUp and LayOut C APIs).
  • Updated OpenSSL to version 3.2.2. Extension developers using any functionality relying on OpenSSL should test that their extensions function as expected.
  • Fixed C API overlay crashes on Macs with Intel CPUs.
  • C API overlay artifacts no longer occur when the SketchUp window was resized.
  • The Ruby and C API documentation has been updated.
  • Fixed an issue where http/https requests could hang when using UI::HtmlDialog.
  • Fixed an issue where http/https requests could fail to send their body in some scenarios when using UI::HtmlDialog.
Stability
  • Fixed a miscellaneous crash at shutdown.
  • Fixed a miscellaneous crash affecting Real Time Viewing.
Security
  • Multiple libraries were updated to their latest versions as part of a security patch to remediate identified vulnerabilities.
Miscellaneous
  • Fixed an issue where the sizing cursor would get stuck between dialog panels when dropping the sizing cursor from one panel onto another panel.
  • Fixed an issue where it was not possible to reset group axes or infer to them, if “hide rest of model” is enabled.
Known issues
The following are known issues that will ship in 2024.0.2 and will be addressed in a future release:
  • High DPI scaling issues and Multi-monitor issues will still persist.
LayOut Release Notes
Stability
  • Switching to a scene without a style tracking enabled and without a cached style object will no longer crash LayOut.
  • (Windows) Fixed a crash that could occur accessing a SketchUp model viewport containing a section plane.
SketchUp Model Viewports
  • Fixed an issue where viewports could shift in select instances when the scene was changed.
  • Fixed an issue which would cause disconnected linear dimensions to reconnect to new points in a SketchUp Model Viewport, causing a shift of the dimensions.
  • Fixed an issue where a Label position could shift when attached to an image that has been resized.
