Adjusting Model Settings
You can adjust settings specific to a model on the Settings panel. Follow these steps:
  1. Air tap the Main Menu icon (image).
  2. Air tap the Settings icon (image). The Settings tab appears, as shown in the following figure.
  3. Do any of the following:
    • Air tap on the unit of measure listed in the upper right to display a list of options. Air tap the preferred unit to display all dimensions in that unit.
    • Air tap the Auto-Select Immersive or Tabletop Based on Scene checkbox to clear or select the checkbox. The checkbox is enabled by default.
In SketchUp Viewer for HoloLens you can adjust settings specific to a model
