Activating SketchUp Pro
Opening SketchUp or Layout
Be sure you've already installed SketchUp Pro.
You need to Open and Activate your Subscription Plan or Trial for SketchUp before opening Layout or StyleBuilder for the first time so that you can agree to the License Agreement. Once you've completed that first operation, continue below.
On MacOS, go to the Applications folder and open the SketchUp folder with the year’s version you want to open. Open the SketchUp or Layout application within that folder.
You may want to right-click on the new icon in your dock, and select Options > Keep in Dock.
On Windows, SketchUp should have created shortcuts on your desktop, but you can also open it from C:\Program Files\SketchUp\SketchUp 2021 (or another year’s version number) by double-clicking on the program file.
You may want to then save the SketchUp and Layout app to your Taskbar or Start Menu icons and then delete the desktop shortcuts.
Activating with SketchUp Pro Subscription
You’ll need to be online to activate your paid plan.
  • A single-user license or subscription seat can only be used by the one registered/assigned user, but that user can activate their license or sign-in on 2 computers.
  • If you don't see the Welcome to SketchUp dialog box when you opened SketchUp, select Help > Welcome to SketchUp.
Upon opening SketchUp, you should see a screen that prompts you to sign in. At this point you need to stop and be sure of which of the 2 SketchUp Pro plan options you've purchased:
Not sure if you have a subscription plan? If you received an email with an account number, then you have the yearly sign-in-activation plan and don’t need or have a license number.
Haven’t purchased SketchUp yet? Simply sign-in to activate a 30-day trial of our highest-tier "Studio" plan!
Newer year-by-year Pro Subscription plans
If you purchased since February 2019 and bought a yearly Pro subscription or if you are a trial user, then go ahead and sign-in with the end-user email address you selected when signing up. Signing-in will activate your subscription.
Older "Classic License" Activation:
If you have a perpetual "Classic" license for SketchUp (the only option before February 2019) then you should've received an email with a serial number and authorization code. Here is how to activate your Pro purchase:
If you're not sure of your license, you can find it in the License Manager.
  1. In SketchUp’s Welcome Window, either click "Add a Classic License" below the sign-in area or click on "License" in the lower left
  2. Make sure you are in the "Classic" tab next to the "Subscription" tab.
  3. Add your classic license serial number and authorization code (we recommend copy/paste).
  4. Once you see the "Remove License" button, you’re ready! Click on "Files" to the left and then click in a Template image to start a new file, or click "Open File" to browse for your existing SketchUp files.
Signing in will NOT activate a "Classic" License SketchUp purchase, but it's still worth doing, as it will sync your 3D Warehouse and 3D Extension Warehouse accounts, and will activate 30 days of advanced "Studio" plan features.
Important Note about Graphics Cards and System Requirements: We recommend having the most current drivers installed for your graphics card(s), and that you check to see if your computer meets our System Requirements.
