Jumping Around in Map View
Note: As of 07/08/2024, SketchUp will no longer offer or support SketchUp Viewer for VR as part of any SketchUp subscription plan. To continue viewing your SketchUp models in VR, use the SketchUp Viewer for Quest, our free viewer for use on the Meta Quest 2, 3 and Pro devices, or the Trimble Connect Visualizer, a workflow extension available through Extension Warehouse. For more information, see SketchUp and the Trimble Connect Visualizer.
In Map view, you can pan around a bird’s-eye view of your model and jump to any location, landing in Immersive mode.
To open the Map view navigator, follow these steps:
- Click the model you want to see in Map view.
- Click the Main Menu icon ()
Click the Map icon () on the left, and the selected model appears in Map view, as shown in the following figure.
In Map view, the following tools will help you pin point the location within the project model where you want to jump in:
- Click and drag the Move icon () to pan the model.
- Click and drag the Zoom icon () vertically to zoom in or out.
- Click the Zoom Extents icon () to have the entire model fit within the window.
In some cases, you might want to jump into a room within a building Here’s how:
- Click and drag the Eye icon () along the vertical ruler. The ruler indicates the height of a plan view section plane that you can position at a height that allows you to navigate to a certain floor of a multi-story project.
- Click the Immersive View icon ().
- Click a surface in the model to jump to that location in Immersive mode.
