Can I install both SketchUp Make and SketchUp Pro?
No, because SketchUp Make and SketchUp Pro are essentially the same. If, for example, you install SketchUp Pro after installing SketchUp, the exporters for SketchUp will be unlocked and LayOut Professional will be installed. The base SketchUp application won't change.
TAGS
