Administrator: Performing a Silent Install
The instructions below are for a silent install using our current installer, not the MSI. If you're using the MSI file you likely already know how to use it.
If you're looking for a Microsoft Silent Install (MSI) file, you'll find it here.
SketchUp has the option to be run silently for distributed installations. You won't need this option unless you're deploying SketchUp on a large scale. If you're working with larger installations and a network license, be sure to read our article on that subject as well: Administering a Network License
Please note, this is an advanced procedure and should only be handled by your network administrator.
Running without an internet connection
You will need to make sure the following prerequisites are installed. These will automatically install if an internet connection is available.
How to run the silent installer with default options
This will install with default options. English as the language, C:\Program Files\SketchUp\SketchUp 2021 as the install directory.
  1. Download a SketchUp 2021 installer. The full installer includes all of the language packs.
  2. From an elevated command line or script run
    SketchUpPro-2021-0.exe /silent
    In Windows 10, you can use the search box inside the Start menu. Type cmd there and press CTRL + SHIFT + ENTER to launch the command prompt elevated.
While the install is running no windows will open. After a couple of minutes, SketchUp will be installed.
How to run a customized silent installer
For customized installs; you can specify the language and/or the install destination path.
  • FEATURES= is for adding languages.
  • INSTALLDIR= is for specifying install destination
Examples:
SketchUpPro-2021-0.exe /silent FEATURE=fr INSTALLDIR=D:\Apps\Sketchup2021
SketchUpPro-2021-0.exe INSTALLDIR=D:\Apps\Sketchup2021
SketchUpPro-2021-0.exe /silent FEATURE=fr,ja
Supported Languages
Feature CodeLanguage
deGerman
esSpanish
frFrench
itItalian
jaJapanese
koKorean
pt_br OR pt-brPortuguese
ruRussian
svSwedish
zh_cn OR zh-cnChinese Simplified
zh_tw OR zh-twChinese Traditional
Troubleshooting
The installer creates an InstallShield.log from the directory where it was run. This can contain information useful for troubleshooting.
