At the bottom of the toolbar you’ll see (...). Choosing that icon opens the Expanded Toolset, where you’ll find the rest of your tools.
The Expanded Toolset contains the following:
Icon | Optional Tool Modes | Tool Name | Learn More |
Select | Select Tool |
N/A | Markup | Markup Tool |
N/A | Insert Image | Insert Image |
Freehand | Freehand Tool |
2 Point Arc | 2-Point Arc Tool |
Arc | Arc Tool |
Polygon | Polygon Tool |
3 Point Arc | 3-Point Arc Tool |
Pie | Pie Tool |
N/A | Offset | Offset Tool |
N/A | Follow Me | Follow Me Tool |
Tag | Tag Tool |
Tape Measure | Tape Measure Tool |
N/A | Dimension | N/A |
N/A | Protractor | Protractor Tool |
Axes | N/A |
N/A | Text Label | N/A |
Create Section | N/A |
Orbit | Orbit Tool |
N/A | Pan | Pan Tool |
N/A | Zoom | Zoom Tool |
N/A | Zoom Extents | Zoom Extents Tool |
N/A | Position Camera | N/A |
N/A | Look Around | N/A |
N/A | Walk | N/A |
N/A | View in AR | N/A |
N/A | Scan-to-CAD | N/A |
Optional Tool Modes
Many tools have optional tool modes. Optional tool modes modify the way you use a tool. If a tool has optional tool modes, you'll see an icon for each available mode. For example, the Lasso tool has three optional modes - Add, Remove, and Inverse. We've listed the icons representing the optional tool modes available for each tool in the table above. For more information on how these optional tool modes work, go to the Learn More link next to each tool in the tables above.
