Happy Holidays! Trimble is closed November 22nd & 23rd for the Thanksgiving Holiday - We will get back to you as soon as possible after the break, thank you in advance for your patience while we spend this time with our friends and families.
Checking Network Licenses In and Out
If you use SketchUp Pro with a network license and need to use SketchUp Pro while you don’t have an active Internet connection (on a plane, for example), you can check out a network license seat for up to a week. After you check out a network license seat, you can run SketchUp Pro when you’re offline.
To check out a network license, follow these steps:
  1. Select Help > License.
  2. Click the Check Out License for Offline Use button. A dialog box showing the number of days the license can be checked out appears.
  3. Click the Check Out button. Your license is checked out, and you can now use it when you’re offline.
  1. Select SketchUp > License.
Note: While your license is checked out, no one else with access to the network license can use that seat. In other words, the total number of seats on the license decreases by one for the duration of the check-out period.
To check in the license, follow these steps:
  2. Click the Check In button.
Tip: If you don’t check in a license, it’s checked in automatically when the check-out period expires.
TAGS
