SketchUp Pro 2020 is here! If you are looking for your SketchUp Pro 2020 license, please visit our License Wizard. - If you have a SketchUp Pro subscription, you don't need a license, just sign in with your Trimble ID.
Opening, Placing, and Closing a Model
After launching SketchUp Viewer, you can open a model from the Home Screen. Follow these steps:
  1. Air tap the Saved Models icon (image) to see the models saved locally to your HoloLens alongside any models you’ve published to 3D Warehouse. Select the 3D Warehouse icon (image) to search 3D warehouse for models, or the Trimble Connect icon (image) for models saved there. Navigating the SketchUp Viewer Interface in HoloLens has details about how to access the different areas of the Home Screen.
  2. (Optional) Air tap the model’s info icon to open a screen that enables you set the model’s default scale.
  3. Air tap the model that you want to open. Your model begins loading in HoloLens, as shown in the following figure.
  4. At the prompt, air tap where you want to anchor your model. The model’s anchor places the bottom center of the model’s bounding box. For example, you can anchor your model to a table, a desk, or the floor. As you view a model, you can change the anchor anytime.
You see your model loading in SketchUp Viewer for HoloLens
After you open and anchor a model, you can interact with the model in Tabletop or Immersive mode.
To close a model, follow these steps:
  1. Move your hand with your index finger extended into your view and gaze into the space around the model (not at the model).
  2. Air tap the Toolbar icon that appears, as shown in the following figure, and you see the Model Viewer toolbar.
  3. Air tap the Home icon (image) to close your model. The viewer asks whether you want to close your model, as shown in the following figure. If you air tap Yes, you return to the Home Screen.
Confirm whether you want to close a model in SketchUp Viewer for HoloLens
