SketchUp Help Center
How Can We Help?
Buying or Upgrading a License
4º marcador de posición
ATENCIÓN: para celebrar el Día de la Independencia, Trimble experimentará una parada que comenzará el lunes, 30 de junio hasta el viernes, 4 de julio. Todos los correos electrónicos sufrirán un retraso en las respuestas durante este periodo.
You can get a SketchUp Pro license in a few different ways:
Tip: If you’re interested SketchUp Pro but aren’t ready to purchase a license yet, download the free SketchUp Pro trial. With the trial, you can run the full version of SketchUp Pro for 30 days. After the trial expires, you need to buy a license and authorize the software to continue using it.
Warning: Because SketchUp Pro network licenses use a cloud-based licensing server, you need to have an Internet connection or to check out a license. Otherwise, SketchUp Pro won’t work. See Understanding your license type later in this article for details.
If you have trouble purchasing a license, open a new browser window and try placing your order again. If that doesn’t help, contact our Sales team if you’re in North America. Outside of North America, check our list of registered resellers who can provide detailed information for purchasing in your area.
In the following sections, you find details about how you can use each type of license and how to upgrade a license. If you ordered a license but want to cancel your order, you learn how to do that, too.
Table of Contents
  1. Understanding your license type
  2. Upgrading your license
  3. Cancelling a license
You can use SketchUp Pro with a single-user license or a network license.
Here’s what you need to know about each license type:
  • A single-user license works on up to two computers. Your constellation of devices doesn’t matter: You may have a computer running Windows and another running Mac OS X. You may want to download SketchUp Pro to both your desktop and laptop computers. As long as your computers are compatible with SketchUp Pro, your single-user license works on two computers. If you’re using a single-user license on two computers and want to move one instance of SketchUp Pro to a new or different computer, you need to remove the license on one computer before you can use it on another. See Authorizing and Removing a License for details. You receive a single-user license if you purchased an individual license at full price or have a student, educator, or laptop license through our education license program.
  • A network license needs an active Internet connection or to be checked out. A network license has a pool of seats that some number of computers can use at the same time. For the license to work, your computer needs to have an active Internet connection as you run SketchUp Pro, or you need to check out a license seat. Like a single-user license, you can use a network license to run SketchUp Pro on a Windows or Mac OS X computer. Businesses with 10 or more copies of SketchUp Pro are eligible for a network license. Also schools with a network lab license are using a network license that expires after a year.
Tip: If your license doesn’t work, check what type of license you have and whether the license needs to be authorized or you need an Internet connection for SketchUp Pro to work.
SketchUp licenses are specific to a version of SketchUp Pro (such as SketchUp Pro 2016 or SketchUp Pro 2015). To upgrade your current SketchUp Pro license to the most recent version of SketchUp Pro, follow these steps:
  1. Look up your license information. (See Finding Your License Information for help.)
  2. Check whether you can use the SketchUp Pro License Wizard.
    • If your serial number ends in ALW, alm, EUW, eum, UKW, or ukm, then you purchased you license directly from SketchUp and can use the wizard. Skip to Step 3.
    • If your license ends in anything else, then your current license is from a reseller. The Search for Reseller tool can help you contact your reseller about purchasing an upgrade.
    • If you purchased an education license directly from SketchUp, contact our Education Team to upgrade the license. You can’t upgrade your license via the upgrade wizard.
  3. Go to the SketchUp Pro License Wizard to purchase an upgrade.
  4. After you purchase the upgrade, check your email for new license information and a link to download the latest version of SketchUp Pro.
  5. Download, install, and authorize SketchUp Pro, using the new license information from your email.
Tip: If you’re active in the upgrade, maintenance, and support plan, you receive an email with new license information after a new version of SketchUp Pro is released. Download and install the new version of SketchUp Pro, authorize the license, and begin using the new version of SketchUp. After you authorize the new version, your old SketchUp license expires after 60 days. Here’s how this impacts the way your license works:
  • If you have a single-user license, the older version of SketchUp continues working on other computers, but you can’t use the old license to authorize new computers. Be sure to upgrade and add the license to those computers in order to continue using SketchUp Pro.
  • If you have a network license, your old license stops working 60 days after the first network user authorizes SketchUp Pro with your upgraded license.
Your SketchUp purchase is governed by these terms and the EULA for your version which can be accessed from the about dialog in the product.
You have 30 days from the time of purchase (not the time of download) to return a SketchUp Pro commercial license for a full refund. After 30 days, you cannot obtain a refund.
To cancel your SketchUp Pro license, contact the Customer Support team.
Note: In order for us to process the refund, we must see "0" activations on the license. Please remove any activations on your license in order to initiate the refund process. License removal instructions can be found here.
OS:
Need Help Fast?
