Terra Design System [Work in Progress]
Drupal 8 Changes
- Important: Look at the Aliases rules below. One is a new important part to allow EN lang fallback to work.
- "Book Page" is the new "KB Article"
- Language and Article ID have been added to the content filters and content display on the Content Admin page
HTML Notes
- Don't use <h1> in content sections.
- <lh> is deprecated. Use a header before the list.
- Table of Contents should follow the example in the styleguide
- If you feel the need to use
style
attributes, let us know, so that we can instead provide a class that incorporates it into the site's style system. - When writing "id"s for anchors, add a class "
anchor
" so that we can adjust for the height of the header. - Write [thing] instead of <thing> because our translation parser gets confused.
- Think of <p> tags like <h1> tags. You can add spans/divs, but you can't put <ul> tags in <h1> tags. Same rules with <p>
Images
- We'll be FTPing all Images to the site until we can get Drupal Components integrated into the process.
URL Aliases
- [IMPORTANT] For now, if you make a new page, you must go to URL Aliases and set the new node's Alias' language to be "None". We will be doing our best to find a way around this manual step in the future.
- Don't do href="123". Instead href="/article/123"
- Leave off the language code, so /article/123, not /de/article/123
- Leave language codes off of www.sketchup.com links
