Happy Holidays! Trimble is closed November 22nd & 23rd for the Thanksgiving Holiday - We will get back to you as soon as possible after the break, thank you in advance for your patience while we spend this time with our friends and families.
Tracing an Image
Tracing an image is an easy (and thus common) way to create a floorplan in SketchUp and then turn that plan into a 3D model. You can also trace an image to model a 2D design that you want to place somewhere in a 3D model. Whatever you’re trying to model, here’s how to start tracing an image:
  1. Import your image into SketchUp. The specific steps depend on the type of image you have. To start the import, select File > Import. Then navigate to and select the image you want to import.
  2. (Optional) Select Camera > Standard Views > Top to get a top view of your image. If you choose this step, also be sure to switch to Parallel Projection as well.
  3. Select a drawing tool to start tracing the image. The Line tool is a popular choice.
If precision is important to you, use a line in your model to scale the drawing.
In the following video, you see two examples of tracking an image to create a floorplan. The first example is a napkin sketch; the second is a drawing plan with precise measurements.
