In SketchUp 2016, when the Preview Pane in Windows Explorer is open and a SketchUp model is opened via File > Open, you might see the following error:
The file <your SketchUp model name> is currently locked by another user. Do you wish to open this file Read-Only?
To fix the problem, you can try the following options:
- Close the Preview pane in Windows Explorer as shown in the following figure.
- Close SketchUp and, instead of selecting File > Open, double-click the file to open it.
- Select the SketchUp model file in Windows Explorer, wait about 5 seconds so that the thumbnail has time to draw in the Preview Pane, and then double-click the file.
- In Windows Explorer, navigate to
C:\Program Files\SketchUp\SketchUp 2016
. Right-click on the fileThumbsUp.dll
, and select Rename. Rename the file toThumbsUp.old
. This will disable the drawing of SketchUp thumbnails in Explorer. - If none of the preceding workarounds resolve the issue, disable any third-party thumbnail software (such as MysticThumbs) that you may have installed. Third-party software can also cause this error to occur.
You might see this error message when opening a SketchUp model by double-clicking the SketchUp file in Windows Explorer, or by right-clicking the file and selecting Open With > SketchUp 2015.
Here's the full text of the error:
This issue occurs when a SketchUp model thumbnail is in the middle of loading in Window Explorer’s Preview Pane at the same time the SketchUp model is being opened.
To fix this issue, try the following options:
- Open the SketchUp model by clicking File > Open from within SketchUp.
- Close SketchUp and then double-click the same model a second time to re-open.
C:\Program Files\SketchUp\SketchUp 2015
. Right-click the fileThumbsUp.dll
This will disable the drawing of SketchUp thumbnails in Explorer. - If none of the proceeding workarounds resolve the issue, disable any third-party thumbnail software (such as MysticThumbs) that you may have installed. Third-party software can also cause this error to occur.
