Section Plane Tool: Creating section cut effects
To add a section plane entity:
  1. Select the Section Plane tool (). The cursor changes to a pointer with a section plane.
    Note: Press the Esc key at any point during the operation to start over.
  2. Click on a face to create a Section Plane entity and resulting section cut effect.
    Note: A section plane will not work on a selection set (you cannot preselect only those items you want to slice). Instead, the section plane will create a section slice in all entities in the current context and, therefore, the slice will expand to cover all entities in the context.
