3D Text Tool: Place 3D Text dialog box
Use the options in the Place 3D Text dialog box to enter and configure 3D text.
Font
Select a Font from the drop-down list to change font. Select Regular or Bold from the drop-down menu to create regular (non-bold) or bold text, respectively.
Height
Type the height, in current modeling units, in the Height text entry box.
Align
Select Left, Center, or Right, from the drop-down list to align two or more lines text to the left, center, or right respectively.
Filled
The 3D Text dialog box allows you to create 2D text with just outlines (edges) or faces, or 3D extruded text. Check the Filled checkbox to create faces for 3D text. Uncheck the Filled checkbox to create 2D text outlines (just edges).
Note: The Filled checkbox must be checked to create 3D text.
Extruded
Check the Extruded checkbox to create extruded (push/pull) 3D text. Uncheck the Extruded checkbox to create 2D text.
The extruded checkbox must be checked to create 3D text.
