How do I draw a sphere?
      Aviso: SketchUp 2015 está aquí! Cuando usted mira este artículo de Knowledge Center, asegúrese de escoger "SketchUp 2015" la caja roja arriba para ver la versión 2015 de ese contenido. Si no hay ningún selector de versión, este contenido se aplica a todas las versiones de SketchUp.
Here's the easiest way to draw a sphere
Don't draw one! Instead, download a sphere from the 3D Warehouse. There are thousands of components available in the 3D Warehouse, including many spheres.
If you prefer to do things yourself
Here's a step-by-step manual method you can use:
  1. Use the Circle tool
    to draw a circle on the ground plane. The first time you do this, you'll find it easiest if you start your circle at the origin point (the point where the red, green, and blue axes intersect). With the Circle tool still selected, hover way out along the top edge of the drawing until the circle cursor turns red or green, and then press and hold the Shift key to lock that inference direction (both of these inference directions are perpendicular to the ground plane).
    Draw a circle on the ground planeLock a red or green plane inference
  2. With the inference direction locked, draw a second circle inside the first, but make it a little smaller than the first. Then use the Select tool to select the face of the first, larger circle.
    Draw a second, smaller circleSelect the face of the first circle
  3. Select the Follow Me tool (on the "Tools" menu, click "Follow Me"), and then click the face of the second, smaller circle. A sphere should result.
    Click the face of the second circleA sphere should result
  4. Use the Erase tool to erase a point on the edge of the first, larger, circle. That circle should be entirely erased, leaving the full sphere.
    Erase the edge of the first circleOnly the sphere remains
Here's a little trick you can do with the Follow Me tool. Instead of preselecting the original circle, select the Follow Me tool, click the face of the second circle, press and hold the Alt key, and then click the face of the first circle.
Want to smooth the circle? If the circle looks a little jagged, try adjusting the rendering options:
  1. Open the "Window" menu.
  2. Click "Display Settings."
  3. Try reducing the size of the extensions and endpoints, or turning them off.
