Title bar
      Aviso: SketchUp 2015 está aquí! Cuando usted mira este artículo de Knowledge Center, asegúrese de escoger "SketchUp 2015" la caja roja arriba para ver la versión 2015 de ese contenido. Si no hay ningún selector de versión, este contenido se aplica a todas las versiones de SketchUp.
Mac OS X
The title bar (at the top of SketchUp) contains the standard Macintosh OS X window controls (close, minimize, and maximize) on the left, and a title bar collapse/expand button on the right. In the middle of the title bar is the name of the currently opened file. A blank drawing area appears when you start SketchUp and the name of the currently opened file is 'Untitled' in the title bar, indicating that you have not yet saved your work.
Microsoft Windows
The title bar (at the top of SketchUp) contains the standard Microsoft Windows controls (close, minimize, and maximize) on the right, and the name of the currently opened file. A blank drawing area appears when you start SketchUp and the name of the currently opened file is 'Untitled' in the title bar, indicating that you have not yet saved your work.
