SketchUp Dimension Tool: Placing diameter dimensions
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
To place a diameter dimension on a Circle entity:
  1. Activate the Dimension tool (). The cursor changes to an arrow.
  2. Click on a Circle entity.
  3. Move the cursor to pull a dimension string out from the model.
  4. Click the mouse again to fix the position of the dimension string.
