SketchUp Dimension Tool: Placing linear dimensions
Dimensions in SketchUp are based on a 3D model. Edges and points can be used to take dimensions. Suitable points include: end points, midpoints, on edge points, intersections, and arc and circle centers. Dimension leaders can be adjusted to span between non-linear points in a model so that your dimensions are as useful as possible in 3D. To take a dimension between two points in your model:
  1. Select the Dimension tool (). The cursor changes to an arrow.
  2. Click at starting point of your dimension.
  3. Move the cursor toward the endpoint of your dimension.
  4. Click on the endpoint of your dimension.
  5. Move the cursor perpendicular to create a dimension string.
    Note: Press the Esc key at any point during the operation to start over.
  6. Click the mouse to fix the position of the dimension string.
    Tip: You can take a dimension of a single line simply by clicking on the line and moving the cursor.
    Tip: You might need to occasionally rotate your model, as you dimension, to position the dimension to the proper plane.
    Warning: Type \n followed by a space to start a new line of text (Microsoft Windows).
The appearance of all Dimensions are set and controlled from the Dimension panel of the Model Info dialog box. These settings affect all dimensions already in the model.
Dimension plane
You can take dimensions in one of several planes. These include the current axial planes (red/green, red/blue, red/green) or the plane aligned to the edge you are measuring. Radius and Diameter dimensions are limited to the plane defined by the arc or circle. Once a dimension is taken and placed within a plane, it can only be moved within that plane.
