SketchUp Select Tool: Selecting a single entity
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
SketchUp allows you to make both single-entity and multiple-entity selections. To select a single entity:
  1. Select the Select tool (Select Tool). The cursor changes to an arrow.
  2. Click on an entity. The selected entity is highlighted in yellow.
Tip: To select or unselect all geometry, choose Edit > Deselect All, press Ctrl+T (Microsoft Windows) or Shift+Command+A (Mac OS X). Alternatively, click on any empty space in the drawing area to de-select all currently selected entities.
