SketchUp Select Tool: Introduction
Select tool introduction
Use the Select tool to specify the entities you will modify when using other tools or commands. The entities that are included in a selection are referred to as the selection set. Activate the Select tool from the Getting Started, Large Tool Set, and Principal Toolbars (Microsoft Windows), the Tool Palette (Mac OS X) or from the Tools menu.
Keyboard Shortcut: Spacebar
