Standard Views: Using the Isometric (Iso) view
SketchUp will move your view to the true Isometric view closest to your current view angle when you activate the Isometric View. Use the Orbit tool to orient the camera approximately where you want the view to be to change to a different Isometric view. Finally, activate the Isometric view to lock into an actual Isometric view. (Remember that true Isometric views require Paraline mode.)
