Scale Tool: Scaling components
Scaling components
Scaling a Component entity scales the individual instance. All other instances of the component will retain their individual scales. This feature allows you to have many differently scaled versions of the same component in your model.
Scale operations within a component's context (such as scaling a Line entity within a component) affects the component definition and, therefore, all instances of the component are scaled to match (all instances of the same Line entity in all component instances).
