Push/Pull Tool: Repeating a Push/Pull operation
Double-clicking on another face immediately after a push/pull operation will automatically apply another push/pull operation, of the same amount, to the other face.
Note: The side of the face that you double-click on affects the direction of the repeated push/pull operation. If your last push/pull was on a front face, and you double-click on the back side face, the push/pull will occur in the opposite direction.
