Offset Tool: Offsetting a face
Offsetting a face
  1. Select the Offset tool (Offset Tool). The cursor will change to two offset corners.
  2. Click on the face to be offset.
  3. Move the mouse cursor to define the offset dimension. The offset distance is displayed in the Measurements Toolbar. You can offset either inside or outside of the edges; on rectangular face or circular face.
    Note: Press the Esc key at any point during the operation to start over.
  4. Click to finish the offset operation.
