Follow Me Tool: Creating a lathed shape
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
You can use the Follow Me tool to create full lathed shapes using circular paths. To create a lathed shape:
  1. Draw a circle whose edge will represent the path.
  2. Draw a face perpendicular to the circle. The face does not have to be on or even touch the circle's path.
  3. Select Follow Me tool (). The cursor will change to a slanted box with an arrow.
  4. Follow the edge of the circle with the face using one of the methods above.
