SketchUp Rectangle Tool: Drawing a rectangle
Drawing a rectangle
Rectangles can be placed on existing faces or separate from existing geometry (aligned to an axes plane). To draw a rectangle:
  1. Select the Rectangle tool (Rectangle Tool). The cursor changes to a pencil with a rectangle.
  2. Click to set the first corner point of the rectangle.
  3. Move the cursor diagonally.
    Note: Press the ESC key at any point during the operation to start over.
  4. Click again to set the second corner point of the rectangle.
