SketchUp Line Tool: Editing a line entity
You can edit the length the of a Line entity, that does not yet bound a face, by using the Move tool. To edit an Line entity:
  1. Select the move tool. The cursor will change to a four-way arrow.
  2. Move over the Line entity to locate an endpoint of the Line entity.
  3. Click and hold on the endpoint of the Line entity.
  4. Move the cursor to adjust the length of the Line entity.
You can also adjust the length using the Line entity's Entity Info dialog box.
