SketchUp Freehand Tool: Editing a curve entity
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
You can change the length of a Curve entity, that does not yet bound a face, by using the Move tool. To edit a curve:
  1. Select the Move tool. The cursor will change to an four-way arrow.
  2. Move over the Curve entity to locate an endpoint of the Curve entity.
  3. Click and hold on the endpoint of the Curve entity.
  4. Move the cursor to adjust the length of the Curve entity.
