SketchUp Circle Tool: Circle entities
Circle entities
Circle entities are a combination of multiple line segments that are connected together to form a circle. These entities act as a single line in that they can define the edge of a face and also divide a face. Additionally, selecting one segment of the arc selects the entire Circle entity. However, all inference techniques will operate on the Circle as though it were comprised of segments. For example, every point on the circle is inferred as an endpoint of the segment. Draw circles with the Circle tool.
Note: You can explode an Circle into regular edge segments using the Explode Curve context menu item (see the Circle Context Menu Items for more information).
Circle entities are comprised of a radius and number of segments. The following image shows a Circle entity with 24 segments.
Note: The model in the previous image contains two entities: a Face entity (in the middle) surrounded by a Circle entity (the circular edge).
Note: Arc and Circle entities are special in that they automatically produce softened edges when extruded using the Push/Pull tool.
