Toolbar control types (Mac)
SketchUp contains a variety of controls you can place into your Toolbar for easy access. The following section covers each of these controls.
Note: Many of the controls on the Customize Toolbar dialog box are tools listed in the Large Tool Pallet section of the documentation.
Standard Views
The Standard Views control gives you quick access to SketchUp's Standard Views (not including a bottom view).
Face Style
The Face Style control allows you to quickly switch between SketchUp's Face Rendering Styles. You can also use the View menu or the Styles dialog box to switch between these styles.
Undo/Redo
The Undo command will undo the last drawing or editing command performed. The Redo Command cancels Undo operations, stepping forward in the modification history.
Shadows (sliders)
The Shadows sliders give you quick access to the most frequently used shadow settings. You can turn shadow casting on and off with the checkbox, and adjust date and time with the sliders.
You can also use the Shadow Settings dialog box to access more detailed shadow settings.
Shadows (icon)
The Shadows icon control toggles shadows on and off.
Layers
The Layers Toolbar provides quick access to several often used layer operations.
Display the Current Layer: The Layers Toolbar displays the current layer name. Any new entities you draw will be assigned to the current layer.
Add a Layer: Click in the text field of the drop-down list and type a new layer name to add a new layer to the model.
Slideshow
The Slideshow control is used to start and stop slide shows.
Model Info
The Model Info control is used to display the Model Info dialog box.
Section Display
The Section Display control toggles the display of Section Planes.
Section Cuts
The Section Cuts control toggles the display of the Section Cut Effect.
X-Ray Mode
The X-Ray Mode control toggles the X-Ray display mode.
Component Maker
The Component Maker creates a Component entity from the selected geometry. You will be prompted to set a few characteristics for the Component entity upon clicking this Toolbar control.
Separator
The Separator is used to add a vertical line to separate controls in your Toolbar.
Space
The Space is used to add a space between controls.
Flexible Space
The Flexible Space is used to add an adjustable space between controls. A Flexible Space automatically adjusts spacing between Toolbar controls depending on the number and size of controls in the Toolbar.
Print
The Print control activates the Print dialog box, enabling you to print the current view of your model.
Colors
The Colors control launches the Color Picker.
Fonts
The Fonts control launches the Font dialog box.
Customize
The Customize control invokes the Customize Toolbar dialog box.
Measurements
The Measurements control contains a field where you can type values corresponding to the currently activated tool. For example, you can type in the specific length of a line while you are in the Line tool. The Measurement Toolbar is used to create accurate geometry.
