Tool bar context menu (Mac)
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
The Toolbar context menu is activated by context-clicking on the Toolbar. This menu contains options for manipulating the appearance of your Toolbar.
Icon & Text
The Icon & Text option allow you to display both icons and names of controls in the Toolbar. The Toolbar shows both controls and their labels as a default.
Icon Only
The Icon Only option allows you to only display icons for controls in the Toolbar.
Text Only
The Text Only option allows you to only display the names of controls in the Toolbar.
Use Small Size
The Use Small Size option provides additional space in the Toolbar by shrinking the size of individual icons. This option does not change the size of textual names or icon groups, such as the Display Style group of controls.
Remove Item
The Remove Item option removes the control that you have selected.
Keep Item Visible
The Keep Item Visible option keeps the toolbar item always visible when the window is resized.
Customize Toolbar...
The Customize Toolbar... menu item displays the Customize Toolbar dialog box containing all of the controls that can be placed in the Toolbar.
