How Can We Help?
Creating Scenes
 NOTICE: In observance of the President's Day in the U.S., Trimble employees will be home with friends and family on Monday, February 20th. All emails will experience a delayed response during this time.
In SketchUp, making a scene doesn’t disturb anybody. In fact, scenes help you save different model views and properties and then present those views to other people.
When you create a scene, a tab appears at the top of the drawing area, so you can simply click the tab to display the saved view. In the following figure, you can see how several views of the Victorian-style house are saved as scenes, with tabs along the top of the drawing area.
Here are a few ways you might use scenes:
  • As you’re creating a 3D model, create scenes so that you can quickly move among different views of your model. You might save views from different angles, like the front, back, and side of your model. Or you might create scenes so you can quickly move among different rendering styles, such as wireframe, monochrome, or textured.
  • Save scenes to go along with a presentation of your model. Instead of pausing your presentation to orbit, pan, and zoom while your audience watches and waits, you can make all these moves before your presentation by saving a scene of every view that you want to show. During your presentation, you just need to click the scene tabs.
  • Save scenes with a model that you share via the 3D Warehouse.
  • Animate a sequence of scenes to show off a model. Learn how to animate scenes in Animating Sections and Scenes.
In the sections that follow, you find out how to add a scene and control what properties you save with that scene. If you want to save changes that you make to a scene, you can do so by updating the scene. SketchUp also has commands for sequencing scenes and deleting scenes that you no longer need.
Table of Contents
  1. Adding a scene
  2. Managing properties saved with a scene
  3. Updating a scene
  4. Sequencing scene tabs
  5. Deleting a scene
  6. Customizing the Scenes manager
  7. Viewing scenes in models imported from the 3D Warehouse
Adding a scene
Before you create a scene, set the view and apply any styles, fog, shadows, or section cuts that you want to the scene to display. Also, hide any geometry or deselect any layers that you don’t want the view to display. All these properties are saved with your scene, although you can update or manage these properties later, as explained in the next two sections of this article.
To add a scene, follow these steps:
  1. Select Window > Scenes to open the Scenes manager. Open the Scenes dialog box in the Default Tray.
  2. Click the Add Scene icon (). The scene appears in the Scenes manager with the default name of Scene 1.
  3. (Optional) Click the Show Details icon () in the upper right of the Scenes manager. Use the options provided to rename the scene (as shown in the following figure), add a description, and select which properties are saved with the scene. The next section, Managing properties saved with a scene, explains how the properties options work.
Tip: If your model already contains one scene, you can context-click the scene tab and select Add, which also creates a new scene. Alternately, in the Scenes manager, you can add a scene by clicking the Scene manager’s Details arrow () and selecting Add Scene from the menu that appears.
If you’re creating a new model of a building and you have a photo of that building, you can create a scene and start a Match Photo operation at the same time. In the Scenes manager, click the Details arrow () and select Add Scene with Matched Photo. You’re prompted to select the photo file you want to use, and then SketchUp switches to Match Photo mode. See Matching a Photo to a Model (or a Model to a Photo) for details about working with the Match Photo feature.
By default, when you add a scene, SketchUp saves several properties that affect the view of your model. In the Scenes manager, the following checkboxes enable you to control which of these properties are saved. Here’s brief introduction to the checkboxes and the properties they control:
  • Camera Location: Remember that SketchUp uses a camera as a metaphor for the way you view your model. The camera properties saved with a scene include the the point of view, including the zoom distance and field of view.
  • Hidden Geometry: If your scene has hidden geometry, this geometry remains hidden every time you load that particular scene.
  • Visible Layers: This property applies if you use layers to control visibility.
  • Active Section Planes: Your model can contain several section planes, which slice your model at a certain point to display a view of the inside, usually from the top or the side.
    Tip: You can use different section cuts in successive scenes to create exciting animations of your model.
  • Style and Fog: This checkbox determines whether the scene saves style settings, such as edge rendering and fog.
  • Shadows Settings: This checkbox tells SketchUp whether to store all shadow-related information, including type, time, date, and so on, with the scene.
  • Axes Location: This setting affects whether the axes display and the axes' position in the scene.
By default, all these checkboxes are selected, so all the properties are saved with your scene. If you don’t want to save one of these properties, select the scene in the Scene manager, click the Show Details icon () to display the checkboxes, and deselect the checkbox for each set of properties that you don’t want to save.
Note that you can’t save updates to a property with a scene if that property isn’t saved with the scene. See the next section for details about making sure you include all the properties you want to save in an update.
Updating a scene
Updating a scene saves any changes that you make to a scene after you create it. To update a scene, follow these steps:
  2. In the Scenes manager, select the scene you want to update.
  3. Click the Show Details icon () and make sure all the properties you want to save with the scene are selected.
  4. Click the Update Scene icon () in the upper left of the Scenes manager.
  5. In the Scene Update dialog box that appears, you can deselect any properties you don’t want to save with the update. Remember that if an item wasn’t selected in Step 3, that property doesn’t save, even if you select it in the Scene Update dialog box. After you’re done selecting or deselecting properties, click Update.
Tip: If you don’t like keeping the Scenes manager open, you may prefer to update a scene by context-clicking a scene’s tab and selecting Update. In the Scenes manager, you can also click the Details arrow () and select Update Scene.
SketchUp adds scene tabs and lists of scenes in the Scenes manager based on the order in which you create the scenes. However, this order may not be what works best. For example, in the following figure, say you want to move the interior scene later in the sequence, after all the exterior scenes.
To change the sequence of your scenes, you use either the scene tab’s context menu or the Scenes manager:
  • Scene tab context menu: Context-click the tab you want to move and select Move Left or Move Right. Repeat the command if you want to move the scene more than one position in the tab order.
  • Scenes manager: Select the scene from the list and click the Move Scene Down icon () or the Move Scene Up icon () in the upper right. The tab order updates to reflect the order in the Scenes manager.
Deleting a scene
If you no longer need a scene, you can delete the scene in the following ways:
  • Select the scene in the Scenes manager and click the Remove Scene icon () in the upper left.
  • Select the scene in the Scenes manager, click the Details arrow (), and select Delete Scene from the menu that appears.
  • Context-click the scene tab and select Delete from the menu that appears.
In the Scenes manager, you can customize how the scene thumbnails and the list of scenes appear.
The following options enable you to control how the scene thumbnails appear:
  • If you don’t want to see the thumbnail images, click the Details arrow() and deselect Use Scene Thumbnails.
  • If you update a scene and want the thumbnail to reflect the update, click the Details arrow and select Update Scene Thumbnail.
Click the View Options () menu in the upper right of the Scenes manager, and you can select from the following options, which control how your lists of scenes appears:
  • Small Thumbnails: You see only thumbnails, not the scene names, and more than ten thumbnails are visible in the list at once, before you need to scroll in order to see more scenes. However, as the option name indicates, the thumbnail images are quite small.
  • Large Thumbnails: See only large thumbnail images of a scene, not the scene name. With this option selected, you can see about six thumbnail images at a time.
  • Details: This is the default option, which shows medium-sized thumbnails, the scene name, the photo if your scene has one, and the scene description. You see more information but fewer scenes in this view.
  • List: See only the scene names in a list. The text is a bit larger in this view than in the Details view.
If you download a model from the 3D Warehouse into SketchUp, your download is inserted into your model as a component. However, components don’t have scenes.
Tip: To see and access the scenes, you must open the model in a new instance of SketchUp, so it opens as a full model rather than as a component in a model.
To open a 3D Warehouse download as a model, click No when a message asks, “Load this directly into your SketchUp model?” You then see another message that asks, “Do you want to open or save this file?” Click Open and you can see and use any scenes saved with the model.
For details about saving, sharing, or downloading models via the 3D Warehouse, see the 3D Warehouse section of the Knowledge Center.
OS:
Need Help Fast?
