How Can We Help?
Moving Entities Around
 NOTICE: In observance of the President's Day in the U.S., Trimble employees will be home with friends and family on Monday, February 20th. All emails will experience a delayed response during this time.
When you’re drawing a model in SketchUp, moving your model (or parts of it) takes on a third dimension. Literally.
This article is your guide to moving things around in your 3D model, from a simple click-and-move operation to moving precisely with 3D coordinates.
Note: The Move tool is humble tool whose name doesn’t show off all it can do. See Stretching Geometry, Copying What You’ve Already Drawn, and Flipping and Rotating for details about the Move tool’s other tricks.
Ready to move? Follow these steps:
  1. With the Select (">) tool, select the item (or items) you want to move.
  2. Select the Move tool () or press the M key.
  3. Click the item you want to move. Wherever you click becomes your move point.
    Tip: Moving is easier if select a corner as your move point. If you’re moving an item because you want to align it with something else in your model, make your move point the corner by which you want to align your item. For example, if you’re aligning the upper-right corner of a cabinet with another cabinet, click the upper-right corner, as shown in the figure.
  4. Move your mouse to move your selection. As you move your item, notice how the inferences and Measurements box change:
    • An inference line appears between the start and ending points of the move. (See callout 1 in the figure.)
    • The distance of the move is displayed dynamically in the Measurements box (2).
    • As you move your item close to other items in your model, you see inferences to nearby geometry. (3)
    Tip: To lock an inference to an axis as you move, hold down the Shift key when the move line turns the color of your desired axis. Or hold down the up arrow key to lock your move to the blue axis, the left arrow to lock your move to the green axis, or right arrow to lock the move to the red axis.
  5. Click the destination point to finish the move.
  6. (Optional) To move your item a precise distance, you can type either of the following during or immediately after the move:
    • Length:Distance: The number you type can be positive or negative, such as 20' or -35mm. If you specify a unit of measurement, that unit overrides your template’s default units. For example, you can type 3' 6" even if you are using metric system as your default.
    • Coordinates: The Measurements box accepts global or relative coordinates. To enter global coordinates, use square brackets, such as [3’, 4’, 5’]. To set relative coordinates, use angle brackets, such as <3’, 4’, 5’>.
To see these steps in action, along with a few extra tips for moving, watch the following video.
OS:
Need Help Fast?
