Sharing styles
Sharing styles
Styles are shared in .style files that can be opened by any copy of SketchUp 6 or above. You must create a .style file to share a style with others. To share a style:
  1. Create a new folder/directory on your computer to contain your shared styles.
  2. Select Window > Styles. The Styles Browser is displayed.
  3. Select the In Model styles from the drop-down list. The In Model styles are displayed.
  4. Context-click on the style name you would like to share. The style context menu is displayed.
  5. Select the Save As menu item. The Save As dialog box appears.
  6. Navigate to the folder/directory you created in step 1.
  7. Type the name of the style in the 'File name' field.
  8. Click the Save button. The style file is saved to your newly created folder/directory.
You can now share this style file with others.
