Styles Browser details menu
Selecting the right arrow next to the styles collections drop-down list opens the details pop-up menu. This menu allows you to perform additional styles-related functions.
Create style
Use the Create style menu item to create a copy of the currently active style in the In Model styles.
Open or create a collection (Microsoft Windows)
Use the Open or create a collection menu item to open an existing collection (or file) or create a new styles collection (folder).
Note: The open or create a collection menu item displays a Browse for Folder dialog box. This dialog box does not display files, only folders. Select the folder or location containing the file and click the OK button. Use the Make New Folder button to create a new collection folder.
Open an existing collection (Mac OS X)
Use the Open an existing collection menu item to open an existing collection.
Note: The Open an existing collection item displays a Open dialog box. This dialog box does not display files, only folders. Select the folder or location containing the file and click the Open button.
Create a collection (Mac OS X)
Use the Create a collection menu item to create a new styles collection.
Save collection as
Use the Save collection as menu item to save a copy of a collection with a new name.
Add collection to favorites
Use the Add collection to favorites menu item to add an existing collection to the list of favorite collections (appearing at the bottom of the collections drop-down list).
Remove collection from favorites
Use the Remove collection from favorites menu item to remove a collection from your list of favorites (appearing at the bottom of the collections drop-down list).
Purge unused
Use the Purge Unused menu item to remove all styles in the In Model styles that are not actually used in your model.
Small Thumbnails, Medium Thumbnails, Large Thumbnails, Extra Large Thumbnails
Use the Small Thumbnails, Medium Thumbnails, Large Thumbnails, or Extra Large Thumbnails menu item to change the size of the thumbnails in the Select panel.
List View
Use the List View menu item to display the styles in list form.
Refresh
Use the Refresh menu item to update the styles appearing in the styles browser.
