The Styles Browser Background panel
Styles also contain options for configuring the drawing area background, sky, and ground colors.
Background button
Use the Background button to select a background color for SketchUp's drawing area.
Sky checkbox
Use the Sky checkbox to have a sky color that is different from the background color. Use the Sky button to select a sky color.
Ground checkbox
Selecting the Ground checkbox selects a ground color that is different from the background color.
Transparency slider
Slide the Transparency slider to adjust the level of transparency for the ground plane. Place the slider toward the left-most position to minimize below-ground visibility. Place the slider toward the right-most position to maximize below-ground visibility.
Show ground from below checkbox
Selecting the Show ground from below checkbox toggles the display of the ground plane from viewpoints below the horizon.
