Naming groups and components within the outliner
The Outliner displays groups by their group names and components by a combination of the definition and specific instance name.
Naming a component definition
As mentioned in the previous
paragraph, components are identified in the outliner by a combination
of their instance and definition names (the definition name is enclosed
in less-than and greater-than symbols). For example, Jim's Office Style 1>. Where you may have several Cubicle Style 1 components in
your model, but only one instance represents Jim's Office.
The component definition name
generally refers to type of component, such as a certain type of cubicle
(Cubicle Style 1) or certain type of video camera (VideoX 8mm camera).
This name can either be established when the component is first created,
or you can accept the default (Component#X,
X being some number) and rename the component definition using the outliner.
To rename the component definition:
  1. Context-click on the component
    in the Outliner. The context menu for the Component entity is displayed.
    Notice that this is the same context menu as the context menu displayed
    when you context-click on an entity in the drawing area (except this context
    menu has a Rename menu item).
  2. Click on the Entity Info menu item.
    The Entity Info dialog box is displayed.
  3. Click on the Definition tab to
    display information about this component's definition.
  4. Type a new name in the definition's
    name field.
  5. Click outside of the
    Entity Info dialog box to save your change.
Naming a component instance
A component instance name is
useful when you want to differentiate different component instances from
each other in the Outliner (the default name for all component instances
is 'Component'). For example, you might want to have different
instance names if several chairs are all from the same definition in your
model. To rename the component instance:
  2. Select the Rename menu item
  3. Type the new component instance
    name in the Outliner.
  4. Press the Enter (Microsoft Windows) or Return (Mac OS X) key to save your change.
Note: You can also use the Name field at the top of a component's Entity Info dialog box to rename component instances.
Use instance names to differentiate different instances of the same definition in your model. This tip is particularly useful if you want to easily locate a specific component instance in the outliner.
Naming a group
You can also name your groups
for easy identification in the Outliner. To rename a group:
  1. Context-click on the group in
