Outliner
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
The Outliner is used to view your Group and Component hierarchies as a hierarchical tree. This feature is great for navigating through large models, restructuring the model hierarchy, locating instances of a particular component, or renaming groups and components. Activate the Outliner dialog box from the Window menu. The following image shows a screenshot of the Outliner on Microsoft Windows:
Identifying Entries in the Outliner Hierarchy
Moving Items Within the Outliner
Filtering Groups and Components in the Hierarchical View
Naming Groups and Components Within the Outliner
