Materials Browser details menu (Microsoft Windows)
Click on the right arrow next to the materials collection drop-down list to open the details pop-up menu. This menu allows you to perform additional material-related functions.
Open or create a collection
Use the Open or create a collection menu item to open an existing collection (or file) or create a new materials collection (folder).
Note: The open or create a collection menu item displays a Browse for Folder dialog box. This dialog box does not display files, only folders. Select the folder or location containing the file and click the OK button.
Save collection as
Use the Save collection as menu item to save a copy of a collection with a new name.
Add collection to favorites
Use the Add collection to favorites menu item to add an existing collection to the list of favorite collections (appearing at the bottom of the collections drop-down list).
Remove collection from favorites
Use the Remove collection from favorites menu item to remove a collection from your list of favorites (appearing at the bottom of the collections drop-down list).
Purge Unused
Use the Purge Unused menu item to remove all materials in the In Model materials that are not actually used in your model.
Delete All
Use the Delete All button to delete all materials in the In Model view, whether they're in use or not.
Small Thumbnails, Medium Thumbnails, Large Thumbnails, Extra Large Thumbnails
Use the Small Thumbnails, Medium Thumbnails, Large Thumbnails, or Extra Large Thumbnails menu item to change the size of the thumbnails in the Select panel.
List View
Use the List View menu item to display the materials in list form.
Refresh
Use the Refresh menu item to update the materials appearing in the Materials Browser.
Get More
Use the Get More menu item to get more materials from the SketchUp web site.
