Entity info dialog box
The Entity Info dialog box displays information about selected entities, and allows you to view and change their properties. This dialog box is context-sensitive, and will contain different options as you select different entities in your model. Activate the Entity Info dialog box from either the Window menu or through a context menu. The following image shows the Entity Info dialog box on Microsoft Windows:
