Components browser
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
The Components browser contains both user-created and pre-built Component entities that you can use in your models. Activate the Components browser from the Window menu.
Note: See component definitions and instances for further information.
The following image contains a screen shot of the Components browser on Microsoft Windows.
