Applying materials to components
      NOTICE: SketchUp 2015 is here! When you look at this Knowledge Center article, be sure to pick "SketchUp 2015" from the red box above to see the 2015 version of that content. If there is no version picker, this content applies to all versions of SketchUp.
Any geometry inside a component that is painted with the default material will be painted when you paint the instance as a whole. Therefore, you can have entities within a component painted individually while other elements painted using the material assigned to the entire component. The following image contains four cars all enclosed in components. The tires, bumper, and windshield have been painted black when editing the component.
Each entire component instance was then painted after being edited, turning each of the faces with the default material to the color applied on the group (green, blue, red, and yellow from left to right):
