Printing to scale
Printing to scale
To print to scale (Windows):
  1. Select Camera > Parallel Projection. The check mark next to the Perspective menu item should disappear and SketchUp will enter paraline mode.
  2. Select the Camera > Standard Views. The Standard views submenu is displayed.
  3. Select a view. The drawing area changes to the view.
  4. Select the File > Print. The Print dialog box appears.
  5. Uncheck the 'Fit to page' checkbox. The Page size fields appear active.
  6. Set the scale using the Scale fields.
  7. Click the OK button. The model prints to scale.
To print to scale (Mac):
  4. Select File > Document Setup. The Document Setup dialog box appears.
  5. Uncheck the 'Fit View to Page' checkbox. The Print Scale fields appear active.
  6. Set the scale using the Print Scale fields.
  8. Select File > Print. The Print dialog box appears.
  9. Click the Print button. The model prints.
