Exporting Epix files
This is a Pro only feature.
To export an Epix file:
  1. Manipulate the view of the model so that it appears as you would like it to appear in the exported file.
  2. Select File > Export > 2D Graphic. The Export 2D Graphic dialog box is displayed (Microsoft Windows).
  3. Enter a file name for the exported file in the 'File name' (Microsoft Windows) or 'Save As' (Mac OS X) field.
  4. Select the Epix export type from the 'Export type' (Microsoft Windows) or 'Format' (Mac OS X) drop-down list.
  5. (optional) Click on the Options button. The Export Options dialog box is displayed.
  6. (optional) Adjust the options in the Export Options dialog box dialog box.
  7. (optional) Click the OK button.
  8. Click the Export button.
Note: SketchUp exports the model using the current point of view with the exception of unsupported features such as textures and shadows.
Note: Your display must be set to 32-bit color in order to correctly export Epix files (Microsoft Windows).
