2D graphic (Epix) export
This is a Pro only feature.
Piranesi is a painting application that enables you to create stunning renderings from your SketchUp models. For more information, please visit the Piranesi web site.
SketchUp allows you to export your models as Epix files for use in Piranesi. Export an Epix file using the Export > 2D Graphic menu item in the File menu.
