Importing 2D graphic files
To import a 2D graphic file:
  1. Click File > Import. The Open dialog box is displayed.
  2. Locate the file you want to import
  3. Click OK to import the file. The image will appear in the drawing area. Your cursor, which will be an arrow, will be anchored to one of the image's corners.
  4. Click anywhere in the drawing area to anchor the point of the image held by the cursor.
  5. Drag your mouse away from the anchor point to increase the size of the image.
  6. Click again to finish placing your image.
