View (Mac OS X)
View (Mac OS X)
The View menu contains menu items that alter the display of entities within your model.
Note: Items in the View menu alter the display of entities. Items in the Camera menu alter your point of view.
Tool Palettes
The Tool Palettes submenu contains all of the tool palettes. There are three tool palettes: Large tool Set, Google, and Dynamic Components. The Large tool Set palette contains all tools needed by advanced SketchUp users. The Google palette has tools for using SketchUp with Google Earth and the 3D Warehouse. The Dynamic Components palette has one tool for activating animated dynamic components. The Sandbox palette has tools for creating terrain and organic shapes.
Scene Tabs
The Scene Tabs command toggles the display of scene tabs. See the Scene Manager topic for further information.
Hidden Geometry
Use the Hidden Geometry menu item to display hidden geometry or entities that have been hidden using the Hide menu item or context command. The Hidden Geometry menu item displays hidden faces with a light cross-hatch pattern (edges are displayed dashed), enabling you to select the geometry. Once selected, hidden geometry can be made visible with the Unhide and Unhide All menu items.
Section Planes
The Section Planes menu item toggles the display section plane entities.
Section Cuts
The Section Cuts menu item toggles the display of any section cut effects.
The Axes menu item toggles the display of the drawing axes.
The Guides menu item toggles the display of guide line entities and guide point entities.
The Shadows menu item activates shadows.
The Fog menu item activates fog. Refer to the Fog dialog box for information on configuring fog settings.
Edge Style
The Edge Style submenu contains options to activate edges, back edges, and edge styles. The edge styles are Profiles, Depth Cue, and Extension. Refer to the Styles Browser Edge panel for further information.
Face Style
The Face Style submenu contains options to activate face styles. The face styles are X-ray, Wireframe, Hidden Line, Shaded, Shaded with Textures, and Monochrome. See the The Styles Browser Face panel for further information.
Component Edit
The Component Edit submenu contains commands to alter the display of other entities when editing components.
Hide Rest of Model
Use the Hide Rest of Model menu item to toggle the display of the model when editing a component.
Hide Similar Components
Use the Hide Similar Components menu item to toggle the display of similar components when editing a component.
The Animation submenu contains several menu items related to scenes and animations. See the Scenes and Animations topic for further information.
Add Scene
Use the Add Scene menu item to add a new scene to the current file.
Update Scene
Use the Update Scene menu item to update a scene if you have made changes to the scene
Delete Scene
Use the Delete Scene menu item to delete a scene from the current model.
Previous Scene
Use the Previous Scene menu item to transition to the previous scene.
Next Scene
The Next Scene menu item is used to transition to the next scene.
The Play menu item starts an animation. See the Scenes and Animations topic for further information.
The Settings item invokes the Animation panel of the Model Info dialog box.
Hide/Show toolbar
The Hide/Show toolbar menu item controls the visibility of the toolbar. You can also modify the visibility of the toolbar by clicking on the toolbar collapse/expand button at the top right corner of the title bar.
Customize Toolbar
The Customize Toolbar menu item launches the Customize Toolbar dialog box allowing you to place command buttons on the toolbar.
