Draw menu (Windows)
Draw menu (Windows)
The Draw menu contains all of the SketchUp drawing tools and provides an alternative to using the, toolbars or keyboard shortcuts.
The Line menu item invokes a Line tool used to draw Line entities, or edges, within the drawing area.
Keyboard Shortcut: L
The Arc menu item invokes an Arc tool used to draw Arc entities, comprised of multiple connected straight line segments (editable as a single curve).
Keyboard Shortcut: A
Use the Freehand menu item to invoke a Freehand tool used to draw irregular, coplanar connected lines in the form of Curve entities.
The Rectangle menu item invokes a Rectangle tool used to draw four coplanar intersecting edges and a subsequent Face entity.
Keyboard Shortcut: R
The Circle menu item invokes a Circle tool used to draw Circle entities.
Keyboard Shortcut: C
The Polygon menu item invokes a Polygon tool used to draw regular Polygon entities, inscribed within a circle, consisting of 3 to 100 sides.
